No spark
carkook
So my car will turn over but will not start.(sohc) I have power too the ignition coil, but no spark coming out of the coil. I replaced the ignition coil, thinking that was the problem, but still no spark. I then replaced the Ignition Control Module. Once again no help. Then I replaced the Crank Position Sensor, under the dist. rotor. AND still no spark. The car turns over and has power, just no spark. Anyone know what the problem could be?
carkook
anyone?
theother1wstolen
Car: 92 240sx Coupe SE
have you tested all of your plug wires? especially the coil wire.
