Ka24de240sxS13 »
https://forums.nicoclub.com/ka24de240sxs13-u89602.html
Sat Mar 01, 2008 11:34 am
hmm... try eliminating the possibilities. Use the spark plug on another wire, see if it sparks. if it doesn't... get a new one. The spark plug could have a crack in the Porcelain, or a number of other problems. Spark plugs are a lot more fragile than we are prone to think. If it does spark, than try using a new/or different wire. Im thinking If both of these dont fix the problem than you have a more in depth problem with the distributor, or the computer not sending spark to that wire. Good luck man
