alright, i am having trouble getting spark out of my coil. i have a blaster 2 coil.i have the green and black wire to negative, and i have the red and black to positive. everytime i crank the motor over and check to see if there is spark coming out of the coil i get nothing.
i have all of the original wires hooked up to the stock coil except the two pos. and neg. coil wires.
I also have another question as to what the other wires going to the stock coil actually do. there is a green and black, a solid black, and a white wire, that plug into the stock coil, and then there is a slide on plug that plugs into the stock coil by itself. what are these all for? do i need them?
My last question is that i noticed there is some type of relay that the green and black, and red and black coil wires split off from.. 4 wires are connected to the relay, a thin orange and red, a thin solid black, and then a thick green and black, and a thick red and black. what does this relay do?
THIS IS A LINK TO SHOW HOW MY WIRING IS CURRENTLY SETUP TO THE T, PLEASE HELP I NEED TO FIX!!
http://putfile.com/pic.php?pic...=x402
thanks alot guys
-tim
