Cyberkreig »
https://forums.nicoclub.com/cyberkreig-u962.html
Wed Mar 19, 2003 10:41 am
Woo Hoo, My tangled mass of sad story has become a resource!! Nils, During my 5 months of working with Modified Motorsports and Heavy throttle to try to get my car to turn over, I learned lots of stuff.
AFAIK, the J4 is a 180sx Type X, ECU. Get the guy on freshalloy to run the number to make sure. It is possible that you have a Type X Ecu (different pinout setup than standard) and Standard Harness. Heavy Throttle mentioned the problem to me in passing. You are a technicaly knowledgeable guy, whipout the volt meter and check the firing order.. You can switch the wires around at the ECU or at the Ignitor.
hope this points you in the right direction
best of luck
joe
