No Spark please help, ignition coil related
89240SXCoupe
Car: 1989 Nissan 240SX Coupe XE
I have a 91 ka24de in my 89 s13 coupe and the engine harness for the kade is cut before the ignition coil/transistor/resistor&condenser so there are no plugs for those components. I have tried to wire them up according to the wiring diagram in the FSM but ive had no luck. If anyone could possibly help me out I am a little bit confused on how to wire it correctly. Thanks!
Forgot to mention the motor is cranking, getting fuel and the getting the right voltage into the coil, but there are bridges and other weird things going on between the three components according to the fsm diagram and its not giving any spark what so ever. all grounds are good too...
