iloverbpowers wrote:Same Problem but not quite as my fuel pump stopped working? it wont prime.
Can anyone take a picture of where abouts is the ignitor on an rb20e or if they could explain exacly where it is id really appreciate it
EDIT: ive also tried the Coil to sparkplug And no spark either
so now you have NO fuel priming and NO spark?? if so, then it is sounding more like your ecu is missing some wires, like power, memory, ground, or IGN.....or if I understand the CAS properly, then your CAS may be bad???
Is your ECU turning on with the key, and if so, check for codes and let us know what it says....
--TJ
