brndck »
https://forums.nicoclub.com/brndck-u4544.html
Sat Dec 19, 2009 7:25 pm
cliff notes first:car started/ran fine yesterday (redtop sr20det with #62 ecu), then i installed the following-550cc sti injectors -t28 s14 turbo-z32 maf (wired per heavythrottle)-tomei #62 ecu reflashed for z maf, t28, 550 cc injectors
NOW i have no spark at the coil packs and no pulse at the injectors, ecu is showing code 11 (crank angle sensor). if i switch back to my old mines #62 ecu, car still has no spark and no injector pulse and shows same #11 code.
so far i have rechecked all my wiring for the new injectors and the z maf, as well as tracing all the wiring for the cas, tps, maf, injectors, etc to make sure there were no shorts or exposed wiring or anything. i am still getting plenty of fuel pressure. i've checked all of the pins on the ecu that are cas related and i am still getting a start signal from the ignition.
i don't have any sort of oem test procedure for the cas, but it is getting power and ground and when you crank the engine, it does produce a 5v reference signal so i don't think it is actually bad.
any suggestions or does anyone in socal have another cas i can borrow for testing/possibly buy?
