oookay, so here is the basics. I pulled the Sr20det our because of what i thought was a spun bearing, it turned out to be a bad crankshaft.....I replaced the crank, rebuilt the entire engine, heads and block, and placed it back into my car.
Everything went fine until i got to hooking back up the harness, now to clarify, this is NOT a new swap, the engine was running in the car before the spun bearing.So I get the harness hooked up, with some trouble and I have a problem, I can crank the engine, the fuel is coming out, but im not getting spark.
the coils are brand new, as are the spark plugs, so im going to rule them out unless someone says otherwise, other then that, I went through most of the harness and i cant find ANYTHING to suggest a grounding point, or shorting.....so can anyone help me?
thanx
Modified by BlackDragon328 at 4:54 PM 1/21/2008
