No spark, new ignitor, maybe CAS? HE
sil80
I just bought a 95 infinity ignitor chip, PN# 22020 50F00 I tryed a countinuty test but Im not sure I i had the right info to test it. Im not 100% sure my CAS is on the right tooth but it sould still get spark just at the wrong time right? motor turns over fine, sounds good. Can anyone help me out. any info will be appreciated! thanksps I DO HAVE FUEL......
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
u throwin a code for the CAS? i beleive in the fsm itll say how to test that
Bongpain
Car: 92 240sx
what about you timing? when i did my sr everything seems good and all the marking and tapes was still on correct but for some reason my timing was off and i would get fuel but it would not start then sometime it backfire. i check that if you haven't yet. and how are you testing for spark? did you ground the coil. if not i don't think you will see spark if you just pick up the coil and crank over the motor. i had that same problem once. if you make a wire with two roach clips at each end that can be used to ground out the coil. try that. good luck
