NO SPARK!! KA24DE???? HELP!
s13mike91
Car: 91 240sx hatch
Okay so yesterday i put my vlsd in and today i was plan on going to the track to run my car. so i drove to the track and i was like the first one there. so i was waiting whil they were setting up. i turned my car off went to go talk to somone. when i came back i went to crank my engine just turned over and over. popped the hood check the coil and plug wires still nothing. so i checked the fuel getting plenty fuel. i grounded the coil pack no spark from that or the dizzy. i checked all wires still nothing. so i went and got a dizzy and a coil pack hooked everything up still no spark from the coil pack or dizzy. so i had an extra good computer hooked that up still nothing. i'vee tried to research the problem and couldnt find anything.
HELP!
mexicanracer03
Car: 95 S15FRONTEND SR20DET and 97 2JZ GT4294/ 93 SC300 Black/ 95 SC300 Green
Did you check your Fuses ? could be posible that one blew.
also check the cap and rotor button. If they have condensation( moitor) they will not start.
s13mike91
Car: 91 240sx hatch
yuhp checked all the fuses. i also noticed that my tachometer doesnt move a bit while cranking the car. all i can think of now is maybe some hidden relay or just a harness issue. it has done this every friday after noon for the past 3 weeks except after a few minutes it will crank back up. the rotor button and cap are in good condition and replaced not too long ago.
mexicanracer03
have you checked the distrubutor ?? tell you buddy if you can use his to test on you vehicle.
s13mike91
Car: 91 240sx hatch
okay i found out the aftermarket tach wire running throught the firewall was sliced open and gtrounding out causing the coil no to work. i fixed and back up and running. i'm going to make it to the track friday night and give it another try.
mexicanracer03
s13mike91 wrote:okay i found out the aftermarket tach wire running throught the firewall was sliced open and gtrounding out causing the coil no to work. i fixed and back up and running. i'm going to make it to the track friday night and give it another try.
sounds great Make sure you get a few runs on Video.
