No Spark In 3 Cylinders
FlukierRory
Car: 1991 240sx Hatchback
Sr20det Forged Internals
Hey guys, i recently removed my sr20det to be get rebuilt. Although it did have a spun bearing it did still run which is why I am confused. I put it back in after getting it back, went to start it up and only got spark in Cylinder #1. To see if it was the coils I put the ones from cylinders 2-4 on tcylinder 1 and they all got spark, so its not the coils. I also used a ignitor chip from a running car so its not that. I also used a full splitfire coil setup including the harness also from a running car. This actually caused the coil in #1 to get extremely hot, but if i switched to a stock coil it didnt get hot. But still no spark. So i need your guys' help because me and my buddy are rather stumped. Thanks!
gingi801
Car: 2009 Nissan Altima 2.5 S
I would start checking the harnesses, and the connections leading to the packs, then try a continuity test from the pack to the end of the harness, from the pavks that aren't getting the spark :gotme
FlukierRory
So I decided to change out the ecu and she started up. But now it idles kinda roughly, the throtte is unresponsive, and then it dies out. Any ideas?
Hijacker
Car: '92 240sx Convertible
'94 F-150
If you just rebuilt it, you'll need to do a break in to seat the rings. The car will run a bit sluggish until things seat in better. If you're having idle and dying issues, make sure timing has been set correctly.
FlukierRory
I set the timing already to make sure it was at tdc and it is now. Could it be the maf maybe
