Baadshah »
https://forums.nicoclub.com/baadshah-u73391.html
Tue Aug 14, 2007 3:05 pm
Sorry new to this site. I have a 1998 Nissan Maxima 5sp Manual. I recently replace motor. The motor I got was out of a 98 Automatic. I installed a new motor and everything was going okay. I went to start to it it was cranking very nicely, So I check fuel, thinkin probably no fuel. Then I check Spark there's NO SPARK at all. I check both of the crank sensors, cam sensors, I even check all the coil packs, all of the fuses are fine as well. Ground wire is also fine. I also checked the furl injectors with the noid light set thats fine too. Also checked the ignition system. All the readings are fine. Please if anyone can tell me whats next, because I can't think of anything else . . . .
