riodcs wrote:ok wen i rewired the plugs for the ignition and coils couple days ago the car started right up....but i had rpm's problemwen i tried to rev it it only went to about 2000 2500 rpm and then it was about to die. so i tought the maf sensor isn't workin properly or at all....i checked the old harness and the silver wires tht r around maf sensor cables have to be hooked up to ground so i did tht i hooked it up to the ground cable tht was goin from maf plug and i tried to start up the car...and surprisingly it didnt start....since then i couldnt figure out wat could of happen...
Dude, if you have to, send it to someone to wire it correctly. Everybody wants to be able to do it themselves, but that doesn'tcome without a nasty penalty in the form "It won't start" or I think my ecu is fried. Or find someone in your area that truly knows what in the hell they are doing wen it comes to this application.
Dee
