No Spark Help
JJ240
Car: 95 white 240
Hi, my friends 92 240 isnt getting spark at all and we cant figure out why. The ignition module is good, the ignition coil is good, the harness seems to be good from the module to the coil we also checked from pin 3 on the harness to the ECU to the module and it seems to not be shorted. Anyone have any other ideas why it will crank and not get spark?
C-Kwik
How did you test for no spark? What do you mean by module?
JJ240
Car: 95 white 240
tried to ground the plug from the ignition coil to the chassis, and also used a timing gun on that same plug. Ignition module=ignitor chip I hear chip for some cars, and usually see module when you try to buy one from a dealer or OEM so I assume they are the saem
C-Kwik
Are you sure the coil is good? If the coil is getting the signals it's supposed to then the coil should fire.
JJ240
Car: 95 white 240
Yeah the coil is good. Nissan found the problem, turns out it was a short in the harness. Thx for the input though.
Silent Drifter
Car: '93 Nissan hatch
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
Alternator, check the alternator I had the same problem an it turned out to be a fried alternator.
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
disregard my last post i was to quick to reply an didnt read the previous post
