DriftX »
https://forums.nicoclub.com/driftx-u61933.html
Sat Apr 07, 2007 2:12 pm
Hello, I recently just bought an 89' 240sx. it was running until I inspected the car carefully and found some chewed up wires. The wires were on the tail end of the ignition. They go to the distributor, ignitor and coil. I cut the frayed end back, and respliced them correctly. Still no spark. I tested the coil and its good. What else can I do? I'm going to put a new ignitor in, should that fix my problem? When I turn the key to accessory, I can hear a relay kick on, would that be for my ignition or fuel pump? Any help is appreciated.
Also, where would the relay for the ignition be?
