no spark ... have three different ignitors.. bad ecu?
1s132c
Car: 1990 240sx
like the title says, do you guys think my ecu could be bad? i have checked everything, i had a kinda small fire with my wiring, i had one wire hooked up wrong and it burned about ten wires, i repaired the whole harness and now i have no spark to any cylindar? what do you guys think, i have tried everything and i have 3 different ignitors and i doubt that they could all be wrong, what do you guys think? i need your help i am officially out of suggestions?
its a 93 240 w/sr20det red top comp #62 if anyone has one for sale that works, please tell me, im ready to try anything
Silvia2NR
Car: 1992 240SX Coupe
spark from the coil?
s13sr20chris
if you are sure that the wiring is right and there are no blown fuses then its time to try a puter.
struckinc
Car: 93 hatch.stock.well mostly anyway-SOLD
97 kouki-stock
12 sentra sr-wifes new car
97 maxima-wifes car-SOLD
02 maxima se- daily
1936 austin 10/4 lichfield
first try to narrow it down before you start changing parts...use a volt meter and see if you have power coming out of the ecu for the ignition circuit to the coils..i think is is a blue and red or white wire in the main harness...should be the only thick blue wire with a stripe..that comes from the ecu and pwers the coils..you may have wire that shorted that you missed...also check all of your grounds
