no spark from the coil pack
YOUNG240SX
Car: 90 hatch
Ok so like the title says,I'm not gettin spark coming out of my coil.I changed the coil pack and cas/dizzy.all fuse and relay fine as far I see.What can it be?
BMAR240SX
Car: 1993 Nissan 240S Coupe
Bump for you man
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
try a different one?
BMAR240SX
Bump
YOUNG240SX
Car: 90 hatch
I changed the coil pack,and the cas/dizzy.there power coming out the coil but not enought 2 spark,more than 10acv.
Bump for some help
Lopin18
Car: '89 Nissan 240SX Hatch KA24E
did u REALLY get a good CAS? :D Its a pain in the ***
anyway, maybe u got a bad connection, check the fuel pump fuse, check the Red/Black cable that runs from the coil goes past the inyector harness etc then keeps going to the Fuse box, check the cable for frying, grounding etc, get a tester btw.... the cable splits inside the harness and goes to the Key ignition assembly and to the ecu on the other end, my split was where the harness wass hooked near the radiator around there..
