andy 200 »
https://forums.nicoclub.com/andy-200-u40647.html
Wed May 10, 2006 10:41 pm
Hi there I am new to this forum and I am looking for some advice I have a fairly modified 200sx s13 ca18det, The problem is that I have no spark,I have changed out all the plugs and coil packs and that does'nt make any difference, I have also had the RAC out and they could only suggest the cam/crank sensor was shot however I swapped that for a spare i had lying around and no luck, If the spindle on the sensor is turned manually I get an injector pulse but when attached to the engine nothing happens! does any one have a clue?
