loystock »
https://forums.nicoclub.com/loystock-u10145.html
Mon Aug 31, 2009 7:09 pm
The ECM sends low-level voltage to each coil which is then amplified by the power transistor in the ignition coil to fire the spark plug. Have you done a 'spark' test of the spark plug? You can try any of the spark plug in Bank 2 (2-4-6)
Since you have done work on the chain guide, it possible that you have a loose connection (or damaged?) on the Crankshaft Position (POS) sensor or Camshaft Position (PHASE). The ECM uses a lot of sensors to control ignition but if either one (POS or PHASE) is not working, the ECU will not send signal to the ignition coils.
Just to be on the safe side, check your battery voltage - >12,5 VDC with engine OFF (>13.8 VDC if you can get your engine to run (charging).
