p00t »
https://forums.nicoclub.com/p00t-u5026.html
Mon Aug 25, 2003 6:46 am
llama, the s14 (95-98) has no external ignition coil, only 4 spark plug wires, no 5th. changes s13->s14, the ignition coil takes the place of the CAS, and the CAS is moved to the transmission (i think?)
texas buy a new distributor cap and rotor, these parts are cheap and you should not be using used ones. make sure the distributor is aligned properly. if you are sure you can get the ignition timing right then the next thing to check would be fuel, do the spark plugs even get wet with fuel if you keep cranking??
