no spark 1991 ka24de
trbosrule1
Car: cars streetbikes atvs
tried to start car in the morning cranks gets fuel but no spark any help at all would be app no prior problems before this help me please
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Trace backwards on this one. You know you dont have spark so you have to move up along the ignition system to test. Is the coil firing? To do this you need spark plug wire pliers. Disconnect the cable from the coil and hold it very close to the terminal on the coil. You should see a spark jump from the coil to the wire same as testing for spark on a plug. No spark could mean the coil is gone(easy case scenario) or the system is not getting the coil to do its job(worst case scenario...electrical wiring problem)
