no sound from the audio and bluetooth
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
mstrina3725
Car: 2009 Infinite G37
i have a 2009 infinite G37 i cleaned battery cable ends now no sound from the audio and bluetooth, I can ii correct this
:facepalm:
Reason: Revised title
mstrina3725
I had to program the power windows but cant get sound to come from the audio system
telcoman
mstrina3725 wrote:I had to program the power windows but cant get sound to come from the audio system
Check your fuses.
Telcoman
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO!
I've revised the title and placed the subject matter in the text box.
Starter
Car: 13 G37X sedan
11 G37S sedan
If you disconnected the cables to clean them, then you may have activated the anti theft feature of the radio. You'll need the activation code for your car. Hopefully you have it, otherwise a dealer will charge you a bunch to get it..
telcoman
Another reason to just let the dealer replace a battery even if its just a few dollars more.
When I had the dealer replace a battery with a 700 cca one on my previous 06 G35 everything worked when I drove off. :)
Telcoman
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
