Southern_Hospitality wrote:I figured out that it only happens when I have the volume high. Do anyone think I may have loose wires or maybe a speaker is blowed?
It could be auto protection circuitry. Perhaps a speaker is blown and is causing greater than normal resistance for that channel? Play music at a 1/4 level and bring your ear close to each speaker. Listen for a raspy noise or no noise at all. Open that speaker and check the connections.
If you suspect a short somewhere else you could pull wires from each of the speakers and measure the resistance between the two wires with the system on. It should give you a reading other than 0 (Zero).
