No sound - amp problem
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
I think I know the answer to this one, but wanted some expert opinions:
Just recently my sound stopped working: NOTHING from radio, CD player, ipod hooked up, Bluetooth from phone, navigation, or back up sonar sounds, etc. Everything else electrical works without a hitch, so don't think it's battery related
Ran the diagnostics menu and amplifier came up as problem.
Checked the fuses - they're good. I think the amp is as Larz says, "titz up"
Gonna bring it to the dealer tomorrow - should still be under warranty (2013, with 56,000 miles), because I know the audio amplifier with Journey package is like $2200!!! :cry: don't wanna pay for that!
but if not, is it possible to just go with an aftermarket amplifier with the same/better specs and just get it installed at a car stereo place? that shouldn't cause any problems with the rest of the system, right?
Craig
Ilya
I think the problem with an aftermarket amp would be the connections. The stock amp is probably sending some sort of signal...when people install aftermarket amps, I believe the stock one is still doing something.
Debonair
Car: 2011 Infiniti M56
You will need to identify the speaker signal wires that are going into the Bose amp, and then test them to see if you are getting a usable signal. based on the system diagrams I have seen it does look like it is versus a digital signal which (like Ilya mentioned) will make the whole project a lot harder. If you are then you can use integration module, aftermarket amp, and an EQ to drive the factory speakers and/or aftermarket speakers and subwoofer in the factory locations.
The factory amp may also run other systems that are not as easily replicated but I am not sure. I will have to look again.
This will be the route I take if my factory amp ever gives up on me and an OE replacement is priced too high for me.
pedsemdoc
R2C Intakes
Oil catch cans
Ilya wrote:I think the problem with an aftermarket amp would be the connections. The stock amp is probably sending some sort of signal...when people install aftermarket amps, I believe the stock one is still doing something.
that's what I was afraid of...there are a lot of connectors back there, I didn't think an aftermarket amp switch was going to be that simple. Sourcing out a used one might be the cheapest way to go if warranty doesn't cover it.
Nielsio
Car: 2010 Nissan Fuga Y51
If you're not in luck with the dealer, just take it to a professional audio shop. They'll hook you up with a JL audio or other quality amp for less. Gl
pedsemdoc
R2C Intakes
Oil catch cans
Update:
so had to work last night, but car was dead, had to take wife's Durango in - don't remember leaving anything on or plugged in.
later the next morning, jumped the battery, voila suddenly I have sound!!!???!!
Wondering if battery going bad...since these cars do weird things when the battery is going bad
At dealer later this morning - Service Advisor tells me the battery is good, BUT the amp is bad and needs to be replaced. However, they have to order it (will prolly take a week) so can't be fixed today. Luckily still under warranty.
Also get a rounded off lug nut off the car - someone torqued that motherF waaay too tight, NO charge!!! Plus, a car wash...she's sparkly again!! I wasn't sure about getting a white car, but that Pearl White finish looks real nice in the sunlight.
beachbum718
Car: 2011 Infiniti M37 S
This happend to my car.amp was broken.dealer replaced it but it was covered under warranty. Think i made a thread about it.ether way im happy i purchased the elite premium warranty. Still have 4 more years or 100k .my car has 47k so im good.the broken amp paid for the warranty itself.so its worth it.
pedsemdoc
R2C Intakes
Oil catch cans
beachbum718 wrote:ether way im happy i purchased the elite premium warranty.
Definitely going to be purchasing this too before I get to 60,000 miles - one electrical thing goes wrong on your ride and you'll be taken for a ride with the cost to replace/fix it.
stm37s
Car: '12 Chrysler 300 SRT8
'11 Infiniti M37 S
'06 Range Rover HSE (Wife's)
'12 Chevy Camaro LS (Wife's)
'95 Chevy Impala SS (sold)
'04 Chevy Impala SS (sold)
'12 Hyundai Veloster (Daughters)
pedsemdoc wrote:Update:
That Pearl White is the bomb yo!!!,lol. The pearl white really shines in the sunlight and when it's cleaned up. Perfect Color to me.
