DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Thu Jul 28, 2005 6:23 pm
The mechanicals fan does more than enough work. The shroud is not needed in most cases, maybe if you live in arizona in the summer and you do mostly stop and go driving then i would say put the shroud on. but even when my head was warped over eight thousandths, my car did not overheat with out the shroud
Just for fun and free ponies you could remove that mechanical fan and wire up your ac fan, you dont need to but you can. To answer your wiring for morons question:extend the green wire and wrap the end of it around one of the posts of your fuel pump fuse, and extend the black wire and wrap it around any unpainted bolt on the chassis, but i suggest one of the headlight grounds. This wireing method is extremely ghetto, but it definately gets the job done, you could wire in a switch, but its easy to forget.
