No running lights
Mod Trainee
I have a '97 Sinatra. My running lights quit working 2 months ago. A gentleman at the Nissan dealership said I needed to replace the dimmer switch on the dash. I did & I still have no running lights. None of the light bulbs are burned out. I can't find a fuse for it. Is there another device that controls the running lights? Do I need to check the wiring? Where & want tool would be good to use? Thanks in advance, MT
s13sr20chris
heh, sinatra?under what conditions? do you have no lights with lamp switch in the parking position? how about regular low beams?
Mod Trainee
All conditions. I beginning to think it might be in the switch. Ya know, the turn signals, wipers, & lights. Any idea's? Thanks in advance, MT
s13sr20chris
just to clarify, what lights are we refering to as you "running lights"?
Mod Trainee
The lights that should be on along with your headlights. My friends are getting tired of following me home at night so I won't get pulled over.LOLThanks in advance, MT
s13sr20chris
i assume you mean the ones in the back. if so i believe they are on the same fuse as the headlights. i could be wrong as it has been a while since i looked at sentra running lights.
