no RPM reading?
KrazyS0b
Car: 89 s13 redtop, f*** Fidanza, Spec stage 2 clutch, Greddy FMIC, HKS SMF Reloaded, HKS SSQV
For some reason i am not getting and RPM or any temp reading? I have an 89 s13. So i swapped out the cluster with an 180sx cluster, but still no RPMs. Do i need to have the DOCH cluster not the 180? or is there something with wiring that would cause this? Thank u for any help
Hijacker
Car: '92 240sx Convertible
'94 F-150
It's probably in your wiring. You should have cut/soldered some wires under the dash going to the dash plug.
Also, I would just swap the tach out into your SOHC cluster.
seanman
Car: 1989 Nissan 240sx
also you need to swap out the sr sensors on the transmission with the ka ones. i think ones the reverse sensor and ones the speed sensor
KrazyS0b
I changed those sensors over they look exactly the same the only difference i can see is the plugs. But are they really different. I did swap three sensors. The speed sensor, reverse, and the one above the speed. Did i do the right ones? I will check the wiring too cause ive had multiple solders break and come apart on me. thank u for the help
Hijacker
'94 F-150
The plugs are the only difference for the reverse and neutral switches.
Grab an FSM and make sure you soldered the correct Yellow/Red wire under the dash. There's a couple running through there and it's easy to get them confused
seanman
i was only aware of 2 sensors that you need to swap out. you have the 89 s13 so of course the stock tach wouldn't work. but i was told to just switch it out with the jdm one from your clip. if you did the wiring right it should work. i just went ahead and bought a 5 inch JDM 4 in 1 tach, i didn't feel like ripping out my hud and risk breaking something. crawl under the car and check your solder, what does the 3rd sensor you said you swapped out look like? where is it? i dont think it would have to do with your tach not working if the engines running fine.
KrazyS0b
i will check the wires and let ya know what i come up with thank for the help
KrazyS0b
the switches where the neutral, reverse, and speed sensor.
Hijacker
'94 F-150
None of the trans sensors have anything to do with the tachometer. The tach gets its signal from the CAS
seanman
ok makes sense. Then its gotta be some wierd wiring problem between your ecu and HUD or CAS and ecu or maybe you just got unlucky with both tachs lol.
Hijacker
'94 F-150
It's probably the dash plug wiring like I mentioned earlier. I've been working on SRs for years and I still get the wires on that plug confused.
WoolyS14DET
Car: 1998 Nissan 240sx w/SR20DET
Hijacker wrote:None of the trans sensors have anything to do with the tachometer. The tach gets its signal from the CAS
The tach gets the signal from the ecm and the ecm gets the signal from the cas !!
KrazyS0b
Ok i looked at the wires today and i printed the wiring FRSport.com and checked it with what i had. Well everything was right. But the yellow/red wire from the white connector was connected to another yellow/red wire but the wire just go to the rest of the harness it doesnt go to the ECU. My water temp is the same way. But everything else connects to a specific ECU pin. is the tach and the water temp suppose to? I have the pin out for the ECU it said pin 3 for Tach. I have the 62 ecu. Do i just splice the wire from the connector to that wire or what? thanks again for the help
KrazyS0b
I was just thinking could it just be that the cluster is bad?
KrazyS0b
Still have no tach but i have water temp now any ideas?
