I think you were right!!!
Short story: I replaced the crank sensor.
Long story: The car died on me while driving after the contacts were cleaned. So I had the "CAM" sensors x2 replaced. The car had the same symptoms after replacing the cam sensors (except for shutting off). I got the crank sensor done today and drove from Santa Monica to Hollywood on the freeway with no problems. Hopefully no issues with this for a while - all sensors have been changed.
The camshaft and crankshaft sensors are essentially the same part, but the angle of connection is where they differ. This 45 degree difference is what causes a 60 dollar increase in price. My mechanic said the cheaper ones could be used, but they would require moving connections.
The diagnostic (P0340) always said the camshafts were of issue ..even after replacing them. Only after reading on another topic on this forum did I realize the codes emphasize the wrong part. My mechanic called a few people and had a conversation with "corporate" when he was trying to figure things out and noted this confusion.
It was a learning experience for everyone. I replaced the 90 dollar sensors (cam) then the 30 dollar one (crank).
Thanks again for all the leads -
MaxBolus wrote:candymanfb wrote:It was a camshaft position sensor issue.
There was a code of P0340 pulled. My mechanic cleaned the connections and it's been fine since.
For all I know it could have been disconnected by accident.... all is good now though.
I was told the sensors are fairly cheap at 25-30 per and would be about half an hour of labor to install.
sorry, late to the thread..
I had a crankshaft sensor go bad and the symptoms were identical. Dealer cleaned the contacts (must be the first step in the diag/t-shooting procedure) and it was OK for about a week, then went bad again.
got the part for 29 bucks, installed in 20 mins, easy job.
Mine seemed to be heat-related, this happened in late summer.
Just in case yours fails again..
good luck!
-m
