No reverse lights
General discussion area for the L32-chassis Altima
Robby368
Car: 2007 Altima
Hey folks, I'm in the process of installing a double din pioneer 3700 radio with reverse camera. I've gotten it all installed and the reverse camera has worked a few times, but now I've lost my reverse lights. There is no 12v power going to the lights, I checked at the purple/black wire at the main harness right before it goes into the fuse box. That's where I tapped into to get the 'reversal signal' input to activate the camera/radio screen.
I have looked at every 10A fuse at the fuse box and under the hood, and I have also checked all 4 of the relays behind the fuse box under the dash. Also the bulbs are not blown.
Everything else appears to be fine, although I have not driven it yet but I can crank it and put it in reverse.
What else could it be??? I've been searching the web all day, and can't find any solid answers. :gotme
telcoman
A poor connection for the 12v feed
If you did a splice, check it and solder the connection
Telcoman
Return to “4th Generation Altima Sedan (2007-2012)”
