No rear brakes
lgharold
Car: 1990 Q45 infiniti
90 Q-45 no rear brakes. Jacked up rear, applied breaks and wheels turn when put in drive. Front brakes work, abs works on frt, I bled brakes, I have a fractory manual, it says replace master cyclinder. Any other suggestions.
Leonard
Q451990
I've never heard of this before... almost seems impossible that you're getting fluid to the rear brakes (had to to bleed them) yet they're not working...
I would make sure you're getting fluid to the ABS actuator by trying to bleed the rear bleeder valve. The master cylinder feeds the ABS actuator.
Heath
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Id agree with the master cylinder thing... Could be the proportioning valve is screwed up.
