No Ps question..along with a hose location.
Brent.S13
Car: 1995 Coupe- Totaled
1991 Hatch- Current
Hey guys. Does anyone know what size belt to put on the water pump and main pulley if you're not running ps? I searched but no good results. Just wanting to know the write up for it, like belt size and such. Thanks guys! Also...
Where does this hose go? I looked, and I just wanna be sure on where it would go...
allenms240
Car: 1991 Nissan 240SX
Is that under the intake manifold? looks like a coolant line that runs just under the collectors.
No idea about PS
Brent.S13
1991 Hatch- Current
Yeah it's under the intake mani, and I figured it was, just wanted to make sure is all.
Yeah I dunno about the ps either, but I figured I'm not going to run it for the simple fact that I've driven a few without it and liked it better than having it, and I don't have a pump or anything for it so I'm not worried about it. xD If anyone knows anything about it let me know how you did it!
allenms240
WAIT, how have you been driving it without the pump and no belt? If I were you, just buy a crappy pump and put it on there with no lines.
For sure a coolant line then, My friend had to take the manifold apart to fix a leak he had there. PITA
s13sickboi
Car: 1997 Nissan Hardbody XE
if you are going to delete p/s DO NOT loop the lines!!!!! do it right... like i am :chuckle: look up how to convert to manual steering.. the only write up i know of is for a miata... check that out... for the belts your going to have to find a sohc to get some parts off of... the alternator brackets and the thermostat housing... swap that out n get a 35" belt from napa..... i will be doing this in the near future so if your lost right now ill do a writeup :bigthumb: but heres some links...
http://www.flyinmiata.com/tech/depower.php
http://www.ka-t.org/forums/viewtopic.ph ... ing+delete
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Definitelty do a write up. I am going to do this one day too.
s13sickboi
aight! writeup comming soon! :ohno: i need the aforementioned sock alt brackets
