No prw sputters & dies. No codes or light.
JennyMax02
Car: 2002 Nissan Maxima SE , 6 speed
Starts up fine. No power while driving cold. As it warms, it starts to sputter , spits, then stalls. Not driveable. No codes or light. 140k Now, tuned up @ 110K. Known defects : oil plug seal gasket leaking. HELP ????
EdBwoy
Having no codes brings an interesting set of challenges.
The things I'd try to address are:
1. Clean MAF sensor
2. Clean throttle body
3. Check crankshaft and camshaft sensors
But first, try to do the idle relearn procedure
JennyMax02
Never hurts to clean. Was leaning towards replacing fuel pump & relay because of mileage. Cleaning is cheaper. Can I reuse gasket on T/body ? How do I do the idle relearn procedure ? ? ? ?
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
JennyMax02 wrote:
Fri Jan 12, 2018 1:08 pm
Try this procedure:
1. Turn ignition switch “ON” and wait at least 1 second.
2. Turn ignition switch “OFF” and wait at least 10 seconds.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Start the engine and let it idle for at least 30 seconds.
6. Disconnect throttle position sensor harness connector (brown),
then reconnect it within 5 seconds.
JennyMax02
Thanks 04PathSE,
You saved me a weeks take home, & the trip ; just for diagnosis at my local N dlr. Many thanks !!
JennyMax02
EdBwoy
Nice job all.
So that fixed it?
