laylu »
https://forums.nicoclub.com/laylu-u5996.html
Tue May 11, 2004 8:57 pm
ok here is my situation, blew up my engine, did direct swap
new oil filter, new water pump, new plugs, new t-stat, using royal purple oil
car idles fine, takes a while for temp gauge to go up to normal point, car over heats over 3000rpms, otherwise gauge stays normal, but the engine is getting hot, losing coolant, and no pressure, engine bogs down when throttled
clutch fan is running, t-stat housing was slightly warm, but not warm like the rest of the motor,
no smoke coming out of exhaust, exhaust sounds subdued compared to before swap, and hardly any exhaust pressure even when throttled
no oil in water and vice versa
any suggestions would be appreciated, thanks
Holly
