no pressure on clutch pedal...
DrifterXJDM
I have a 91 240sx I replaced my slave because it started leaking until it gave out and I can't go to any gear at all. After I replaced the slave I vacuum bled it and pressure and the pedal goes straight to the floor so I replaced the master I thought probably just a bad master also but I bled it and everything still the same... help anyone is there some special thing I have to do???
w1ngzer0
Car: Pfft. i don't own a box
when i had my slave,mater and a new clutch put in i had no preasure on the stock replacement. Untill after 50-100 miles then the clutch started getting preasure.
I guess it's a break in thing. But man was it weird. lol
s13sr20chris
damper box by the slave has air in it. just remove the damper box and bend hardline to reach slave cyl hose.
