no pressure in clutch
nissandude457
i recently helped a friend replace his clutch, we replaced it fine, but when we hooked up the slave there was no pressure in the line, we bled it millions of times and still no pressure, does anyone know whats up, all i can think of is a leak but i havent got a chance to check yet
eddiec
Car: 91 S13
are there any leaks? if not then keep bleeding, assuming everything is installed correctly. remember to top off the clutch reservoir frequently. if you let that go dry while bleeding you just started over.
