No pre-wire foglight in my base model 2009 altima sedan?
mcsniper703
Car: 2009 Altima Base Black
I have 2009 Altima Sedan base model, I had looking for pre-wire foglight and found no wire anywhere behind the bumper. Doe anyone know if the foglight wire is already wire on base model or likely not? Is it possible to buy foglight wire at the dealership part and it be plug and play wire? Thank you
DarkScorpion
Car: 2008 Altima Sedan 2.5S
most base model 2.5 sedans are not prewired. If it's not prewired, you're going to have to run the wires from your fusebox to the fog lights themselves (and find a common ground) in order to use the OEM light stalk with the foglight switch. After you run the wires, everything else is plug and play.
mcsniper703
DarkScorpion wrote:most base model 2.5 sedans are not prewired. If it's not prewired, you're going to have to run the wires from your fusebox to the fog lights themselves (and find a common ground) in order to use the OEM light stalk with the foglight switch. After you run the wires, everything else is plug and play.
oh, what kind of wires do I get from?
khisanthax
That means you have to run the way from the fogs to the stalk and from the fogs to the battery, right?
