theother1wstolen »
https://forums.nicoclub.com/theother1wstolen-u54366.html
Wed Feb 27, 2008 9:25 am
So for years now i havent had much power to the wheels (92 ka24de) and im still wondering what it could be, its not the fuel pump, its not a vacuum leak, and i just pulled my egr, aiv, and carbon canister, no change except i know have a rock solid idle. any one have any ideas what it could be? My injectors look clean, and i run seafoam through the tank pretty often so they should work fine, also could not enough transmission fluid cause low power? (the car goes when its in gear and the acellerator pedal isnt pressed, so its not so bad that i have to gas it to move) any suggestions at all would be greatly appreciated.
