The power windows don't work and the trans is in fail safe mode plus the engine is in failsafe.
From what I can tell the Green w/ red tracer wire has a short /cut in it somewhere after the fusebox (have power at the fuse 26). does anyone have a picture/s showing where the junction points are for this wire? I'm 95% positive that once I figure that out everything will return to normal.
I have the FSM, I have mitchell, I have alldata. None have the exact info I seek. I'm not terribly keen on taking apart the dash and the wiring loom to trace this wire all the way back, so hopefully someone can help
