I can easily tell you what they mean, but you still have not used the power of your computer to do your own homework. I'll tell you this, you have a wiring issue in your harness. Find out what those codes mean and start inspecting your harness for a possible rookie installation. Guys please let him look for this information as this is the way he's going to learn just like most of you did. Good job on reading the ecu's codeswillystyle240 wrote:well here are the codes 12,34,51,23,45 what are they.
Download a FSM (factory service manual) from the numerous links posted here. Read it, then read it again, the memorize as much of it as you can and keep it handy for reference. Over 90% of questions I see asked on here can easily be answered via some reading of the FSM. I understand it's much easier and less daunting to just go and make a post about it here (I'm guilty, I've done it many times) but trust me the more you use the FSM, the more you'll realize how convenient and useful it is and the less you'll be asking questions on here in the future. Also welcome to NICO, it's always good to have another CA owner onboard.willystyle240 wrote:some one please help.
12= Your afm or it's circuitry is experiencing a fault which usually will trip code 34 (hopefully you wird-up the knock sensor) which usually trips code 45 (leaky injector) as a part of it's failsafe mode and if that doesn't help you got a leak somewhere in your piping or you've burned some wires perhaps the afm wire on your exhaust? You have to look your car over real good. We're not there, so we only can give hypothesis as to what your dilemmas are.willystyle240 wrote:ok im new too this forum thing ive never gotten on one before so some of these things your telling me like stickeis what is that. i got my car running good it was pretty powerfull but while i was test driving it back fired not real bad but it did and then it just started missfiring and wont idle and wont get over 50 mile an hour or 3000 rpm and is running so rich that it just pours black smoke out the tail pipe. and i tried to down load the fsm but the only computer i have is at work and it wont download the manual. so some one please help me this is my only driver and the only reason i did this swap is because my ka threw a rod threw the block.
no its internally waste gated.Masterdebater wrote:ur t28 has an external wastegate? wow..anywho try checking all ur vacuum lines cuz mine did this when i had a gay homemade boost controller on it and it was effing up the vacuum
Like he says, post a pic of your set-up! Because you're firing-off information and we're feeding back information that's getting nothing resolved. What ecu are you running? Is it chipped? If it is chipped there's one of your problems right there. If it's not chipped, start looking at your harness because obviously something's wrong. Also, check the voltage of your AFM signal wire while blowing through it because I've seen bad afm in the past that puts out enough voltage to screw-up an ecu real good.Zero260 wrote:timing is 15* BTDC, read the FAQs at the top of the forum and you'd know that.
you don't need a boost solenoid, you do need to have a vacuum line running to the wastegate accuator on the turbo thought.
can you get any pics of your motor/turbo set-up posted up?
that might help us help you.
nope, a ka24e will work, but DE won'twillystyle240 wrote:i have my maf from my ka24de will it work or what mafs will work and how would i have to wire them if i used them
