no power,wastegate opens eraticaly
mike187
Car: 240sx
i just finally got my car running again,the engine just got rebuilt and i sent it to the tune shop, i have a 89 240sx with sr20det,upgrades apexi power fc with map sensor,550 injectors,t3/t04e top mount turbo,38mm external wastegate,graddy profec b spec 2 boost controller,so long story short the tune shop tells me my car is creating 105 hp at 8 lbs and 169 hp at 18 lbs,very weird,there explanation was i needed a new turbo,this doesnt make sense to me cause if its hboosting 18 lbs or more i dont see how it can be bad,i got the car back and noticed no matter where i set my boost controller the wastegate will pop open around 6 psi and will open n close eratically as it goes up in boost,i dont bleave its the boost controller because when on the dyno they were using a manual boost controller and it was still occuring,the boost controller is set up right and i removed it and the diaghram is ok and spring which is blue which i bleave is 7lbs which the boost controler should compensate for,im totaly mind blown on this and have no answer and have a hard time beleaving its the turbo,the tune as wel as everything else seems to be good,thank you for any help and feedback
ashibah83
Car: 93 SUPA BLACK COUPE
timing, check it, double check it, then re-check it.....if its not that, check your compression, and ALL of your vaccum lines, also check for boost leaks
fender_dude
Car: 1990 Nissan 240SX
Is timing really an issue in regards to eratic boost and the wastegate acting up? I figure if the timing is off the car would just take longer to boost but I'm most likely wrong. I am having a similar issue and wondering if timing could have anything to do with the car not boosting.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
At idle what does your wastegate read for vacuum?
