91white_ka »
https://forums.nicoclub.com/91white-ka-u134171.html
Fri Aug 21, 2009 8:56 am
Ok so quickly to get everyone on the same page. I have a 90 hatch shell, with a dohc swap. It's a 5-speed, base model, manual everything.
Let me start of by saying I HAVE NO SOHC WIRING IN THE CAR AT ALL!. Nothing is cut at all,Every piece of wiring is from a 92. Motor is from a 96. I have an S14 upper intake mani. All emissions removed. Windshield squirters, A/c, and emissions wiring is still present in the harness but not plugged in. Ok so I just rebuilt the motor, and wired the car up. When I turn the key on I get power to the fuel pump fuse, but not to the relay (tested with a multimeter) If I jump a wire from the batter to the "out" prong of the relap the pump comes on and the car runs fine. Any ideas? Thanks.
By and idea's I mean does anyone have any ideas on why there would be power to the fuse and not the relay? Certain grounds to check? Maybe a connector? I'd like to check some stuff before I pull all the wiring out an go over it again.
