No Power to St Signal Help
Warlord22
Car: 89 240sx,90 Talon Tsi,01 Cougar
car wont start so i found that a fuse was bad then come to find out there is no power going to the fuse in the first place so what do i do help will be much appreciated and the fuse in in the driver side under the dash which says ST SIGNAl
theother1wstolen
Car: 92 240sx Coupe SE
does it have power when the key is turned to the start position? and if not, does the ignition switch have power? if yes, youll need a new ignition switch, if no, keep moving down the line.
Warlord22
nope no power with the key on and by ignition switch what do you mean exactly are you talking about where the key goes into bare with me i am not a word person
Warlord22
how do i check if the ignition switch is getting power because the car trys to turn over but cant for some reason
theother1wstolen
if the car is trying to turn over the start signal has power
Warlord22
did you mean replace the whole ignition or just the connector part that goes into where the key goes into
Warlord22
still need hhhhhhheeeeeeeeeellllllllllppppppppppp
impact240sx
Car: 1993 240sx Sr20det Gt2871R 2003 350z 1991 240sx Sr20det 2004 Land Rover DISCO
To check if its ignition switch, take a wire with bare ends and connect some of the wire outputs on the opposite side of where the key goes in, vitually you are hot wiring to see if it starts, but if still no go i'm gonna guess either a bad connection somewhere or bad relay.
Warlord22
cancel everthing before this is how it all started when tighting the coolent bleeder screw a spark came out whichi stoped and notice that the wires were exposed from the first injector so i taped them up and when i went to car the car nothing i checked all fuses and they are good so what do i do now
hardyhunter
Car: 2003 Nissan Frontier 4x4
I didn't see any post about how you solved the problem. My Nissan is doing the same exact thing. Would you mind telling me how you fixed your problem? My "starter signal" fuse isn't getting power, either. It's a 7.5 amp fuse, and it's good. Motor cranks, have spark. Just put a different fuel pump in the tank and checked for voltage drop from the battery to the fuel pump....didn't show any drop on the multitester. Thanks
