Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Wed Mar 28, 2007 11:50 am
No, if you overtighten the KS, it can cause it to read as if it were bad. If you did not break the crystal, then it will be fixed by backing the bolt out and tightening it to spec.
If you are using a 12v test light, you won't get anything anyway, since it will be a 5v signal. This is because it is a hot source coming from the computer, and they never use a hot source coming from the computer unless it is a reference voltage. They provide ground in that case.
EDIT: the KS makes the voltage, it is not provided any.
Loosen it and tighten it to specs, then see if you have a code.
Modified by Chezedik at 6:56 AM 3/29/2007
