Thank you very much for your help.i'll check all my relays and check power to them and let you know the results.Ken@PTUNING wrote:Likely the ECU is not being turned on which is why your fuel pump isn't priming. The injectors are on the same circuit that supplies the ECCS relay. Make sure your fuses are fine. Make sure the ECCS relay is turning on (or getting power).
Okay so i'm now at least getting power to the injectors and the pump is priming when i'm trying to crank the car, I just need to replace my fuel injector O rings, and get the battery charged up to test everything out. I'll be doing everything tomorrow, and let you know if i finally get it started. Thanks again, I'm finally a step forward in all this.Ken@PTUNING wrote:Likely the ECU is not being turned on which is why your fuel pump isn't priming. The injectors are on the same circuit that supplies the ECCS relay. Make sure your fuses are fine. Make sure the ECCS relay is turning on (or getting power).
I work at Performance Tuning, Inc. We normally go by the name PTUNING. I am the assistant dyno operator as well as a service adviser and tech when needed. I personally tuned my own S13 on a Megasquirt MS3X (KA24DET, GT2860RS) and have dabbled with AEM, Haltech, Hondata, and Nistune. I'm also familiar with UpRev, EcuTek, Cobb, and HP Tuners.Oniiscythe wrote:the Positive battery wire is a Zero gauge wire, i'll try jumping it from the front like you stated and see if that makes a difference.i'll be doing that possibly late afternoon tomorrow. I'll let you know the results then, and another quick question i noticed your name is and was wondering if you are really a tuner?
