no power to injectors
661s13
Car: 240sx
i did a motor and 5sp swap into my s13 i just put a better running ka24e in and now i dont have any power to the starter or to my injectors any suggestions?
661s13
Car: 240sx
ttt.....no power to injectors
fear@loathing
Car: 1990 s13 240sx hatch
is the new engine and transmission from the same year car as yours? did it come with a new wiring harness? if your useing your stock wiring harness it may not mate with the new engine check all ya plugs make sure they are cliped tight
661s13
Car: 240sx
i believe its out of a 1989 hatch and i have a 1990 coupe so i think the wiring harness are the same and ive triple checked all my plugs and grounds
fear@loathing
strange the only other things i would think of doing if you havent already check fuses and take a multimeter to the injector plugs. and if you are confident in yourself take apart your harness and trace the wires see if any of them are not connected. i have solved all of my wiring issues with my swap from takeing the harness apart COMPLETELY lol
661s13
Car: 240sx
the car ran fine with the original motor and auto transmission and its the same harness i didnt change that... how about a relay thats the only other thing i can really think of is there any way too tell if a relay is bad?
fear@loathing
a volt meter is essential for all wiring work and just test for power
