No power to ignition. But has power to fuel pump and other accessories.
Need2Boost
Hey guys. I have a 92 convertible that I recently put a rb20 in. I got everything hooked up, but I dont have any power to the ignition. No relay kicking or anything. However, I do have power to fuel pump, lights, and other accessories. Any ideas? Thanks
Shocker
Car: 89 240sxHB rb26/30
make sure your bat is fully charged. i know it sounds stupid.. but it happened to me.
Valley
Car: 00 celica gt-s 89 240sx hatch
do you have spark and do you have injectors?
if you have neither it is either CAS, ecu, or wiring problem.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Either that, or you might have a relay that is bad, Check all your fuses and relays, and make sure they click/ arent burnt out
Need2Boost
heres the thing. the rb20 was installed in my 89 coupe. was running at the time, then I took it and put it in my 92 convertible. i think its just a bad relay or wiring for sure. but just cant trace it.
Kansei240sx
Was the Vert an automatic?
Need2Boost
yeah it was. but i dont think its a factor as I already wired up the inhibitor switch.
Need2Boost
anymore idea guys. i test out the relay, they seems to be working fine. it just wont crank at all.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
suppposed to be a ground for the alternator from the ignition switch. Start there. I.E. When the igntion relay has power from ign switch the alternator should be receiving 12vdc it has a relay itself which closes and cranks the engine. If it was from an automatic and now you have a manual you won't have that 12vdc to close the relay. If you need more help contact me at [email protected]
