no power to ecu
1FOUNTAIN
Car: 24osx
as the title says one day i was driving and all the sudden the car died i looked down at my PFC and the light was off as if the key was off but my guages and everything else still works the car still turns over but the ecu never lites up iv tryed 3 ecu's same thing for all can anybody help i need my daily driver back
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Sounds like a broken connection somewhere.. Start checking your wiring
1FOUNTAIN
Car: 24osx
your probably right which is why when i get it runing im trading it for a kat
PyR0NiAk
LOL... You think KA wires are different than SR wires and don't break? A lot of sense that makes.
PyR0NiAk
46 ECCS backup power - Red
47 ECCS power - Black/White
48 ECCS ground - Black
My money is on a bad ground... ;)
1FOUNTAIN
Car: 24osx
i no KA wires can brake 2 but thair are a lot less connections to go wrong thanks for the wire coler help tho
PyR0NiAk
Care to explain how there are less connections? I have no prejudice against people liking KAs... But I do NOT like false info..If you look, I posted the SR ECU pinout in this forum. Find a KA pinout, and I'll guarantee there are just as many wires.. Especially considering, when you do the wiring harness conversion, you don't add anything.. You just cut and solder the SR's plug in in place of the KA's plug.
1FOUNTAIN
Car: 24osx
PyR0NiAk wrote:Care to explain how there are less connections? I have no prejudice against people liking KAs... But I do NOT like false info..If you look, I posted the SR ECU pinout in this forum. Find a KA pinout, and I'll guarantee there are just as many wires.. Especially considering, when you do the wiring harness conversion, you don't add anything.. You just cut and solder the SR's plug in in place of the KA's plug.
maybe my wiring is just a hack job but on a stock ka has uncut wirers, i have extended wirers cut wirers going to nothing spliced wirers i just feel if i had un swaped motor i would have less wiring problems
PyR0NiAk
That's because of the person who did the job, not the motor. You should consider investing less than $300 in a brand new harness premade for your swap. No random splicing or anything. CLICK HERE FOR DETAILS
CRyan
Car: 1997 Nissan 240SX
Putting a KA-T in is like bondage. It seems fun at first, but eventually, its pretty open that its just making you butt-hurt.
OPINION.
PyR0NiAk
CRyan wrote:Putting a KA-T in is like bondage. It seems fun at first, but eventually, its pretty open that its just making you butt-hurt.
FACT
Fixed that for you. ;)
CRyan
FACT
Its like Hijacker never left!
PyR0NiAk
lol.. He WAS the one that chose me to take his spot.
