driftingpumpkin »
https://forums.nicoclub.com/driftingpumpkin-u50072.html
Fri Nov 03, 2006 12:32 pm
I just swapped a newer KA24DE into my 89 hatch, and I got it started with with starter fluid, but the fuel pump wasn't cutting on, but the ecu light was on. So I cut the black pink fuel pump ground wire by the battery, and grounded it by the battery to get the fuel pump to cut on. With this wire grounded the fuel pump now cuts on, but the ecu led goes off, and I have no spark, unground the wire and the ecu led cuts back on, but the fuel pump doesn't cut on. Connect the black and pink wire back like stock, and the ecu led cuts on but the fuel pump doesn't cut on. Another issue, is when I cut the head lights on, and the horn blows, not sure if they're related issue. I have swapped out pretty much all of the green and blue relays thinking maybe one was bad, from one of my other 240's and had no issues, still no luck.
Anyone think of anything to possibly try to get the ecu to stay on, and fuel pump to cut on?
ThanksJames
