Spooled_GTIRSENTRA »
https://forums.nicoclub.com/spooled-gtirsentra-u47677.html
Fri Feb 02, 2007 9:02 am
yes theres a resistor just to the right of the coil, it has 3 wires goin to it, i think thats the power transistor. and there is also the one near the intake manifold that has 4 wires to it that would be the resistor and condenser. where should the coil get power from, the ecu? or is there a relay or a fuse it goes through? or anywhere i can check to see if any of it was getting power.
thanks for the help, tony
