So I just got a 1984 300ZX Turbo from my Uncle for free. It's sat awhile and has it's problems, I have some questions because I'm new to these kind of car.
1. I have no power to anything. The battery is good, and I just replaced the cable clamps and cleaned the grounds. I checked for power and the fusible links and didn't get anything. Which means the problem is between the battery to starter cable or the starter to fusible link box right? Anything special to check first and foremost?
2. I'm going to replace the timing belt, tensioner, and water pump, is there anything else I should replace while I'm at it? And is it pretty hard to replace the timing belt?
3. My Uncle had said that the turbo compressor is bad, so what does that actually mean? (Never had a turbo car before) Do they go out often? Are they easy to replace? What are the signs of a bad turbo compressor?
4. What's the name of this part? I think in the manual it said it was the FICD?
Thanks for putting up with all the amateur questions guys.
